587,414 active members*
3,255 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Won't cold start in cold weather.
    Jun 2004
    2
    I have a 15XT which errors out during cold start in cold weather. If you let it warm up after start up (up to 1 1/2 hours or 15 minutes if you put a heater in the side cabinet) it will continue on with the cold start with no problem. Since all 3 axis error out I assume its not the axis amps failing but a power supply problem to the amps. I have 187 VDC at the blue cap although the output on the solid state relay is only 84 VAC (input to the relay 120 VAC) is this about right? Fault errors are either #1 or #3 for X,Y, & Z. Once it cold starts it will run all day without problems. Got me stumped.
    Aug 2014
    22
    Re: Won't cold start in cold weather.
    Maybe test this ?
    http://www.cnc-arena.com/en/forum/so...m--202164.html
    Don't know if it will help, but its easy to check.
    Mar 2008
    683
    Try jogging the table through the full range of motion on the axes then back to the CS marks. Then run the CS command.
    How cold are we talking.
  1. Will cutting in cold weather damage laser?
    By wintertime in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-08-2011, 06:21 PM
  2. damn this cold weather
    By stk2008 in forum DIY CNC Router Table Machines
    Last Post: 12-16-2010, 03:08 PM
  3. Cold weather is a comin'.....
    By pete from TN in forum Benchtop Machines
    Last Post: 11-15-2010, 06:46 AM
  4. 904-1 cold start
    By yeepman2 in forum Fadal
    Last Post: 05-02-2006, 02:58 PM
  5. Machining in Cold Weather
    By Sprew in forum Uncategorised MetalWorking Machines
    Last Post: 01-30-2006, 05:10 AM
