I posted this in the PCB area because I feel the Wolfgang spindle is targeted directly for PCB isolation routing. I'm not going to be doing large pockets and heavy hardwood carving with it. I'll use my Porter Cable for that.
This is the motor wolfgang uses on his spindle?
http://www.herbach.com/Merchant2/mer...de=TM99MTR3285
Here is a motor I purchased at Princess Auto for about the same price PN: DF651(2)LG. The reason I mention it is because someone else mentioned using it for a replacemment for the wolfgang but I think that might not be a good idea. Here is a PDF the salesman at Johnson sent me with the specifications for the DF-651(2)LG.
There are probably more motors with the same physical dimensions and shaft size. It would be nice if you find one list the motor here.
Ultimately I would love to control the speed of the motor from Mach3 using PWM. I have a simple circuit to control the on/off and I will post it here when I have it done up in Eagle.
Brent
