Hi Guys,
I'm experiencing some difficulty to wire three leadshine EM-705 Enable inputs and Fault outputs in a PMDX-126.
According to EM-705 software manual, Enable inputs could be used to reset the drives in case of faults. As I didn't find any previous wiring diagram, I tried to follow the PMDX-126 application notes regarding the wiring diagram of ERR/RST from Gecko drives in the PMDX breakout board.
I also wasn't able to make the Fault input in the PMDX-126 to work, probably because I didn't use any resistor in the diagram, although I don't know if a resistor to use 12v or 24v is really indispensable.
Has anyone been able to successfully wire the ENA and FLT connectors of the EM-705 in a PMDX-126? In this case, how did you wire it?
I thank you all in advance for the help.
My regards,
Daniel.
