587,646 active members*
2,977 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > WIRING DIAGRAM FOR NEW SX3
Results 1 to 12 of 12
    Mar 2008
    3655
    Can anyone please post a wiring diagram for the newer SX3 motor control with daughter board? Can you explain how to hook up a Cnc4pc C6 speed control board in the SX3? P1? P2?
    Thanks,
    CR.
    Jun 2007
    21
    Circuit Diagram for SX3 Controller Board
    Hi, here is a copy of the Super X3 controller board circuit diagram. I hope this helps.
    Alex
    Attached Files Attached Files
    Jan 2005
    1695
    Interesting... Do you know the origin of the diagram?
    Jun 2007
    21
    Wiring Diagram (Circuit Diagram) for the SX3 Controller Board
    Quote Originally Posted by H500 View Post
    Well, it is a long story. I intially had some of the earlier Panel and Controller board set which I was trying to get the circuit diagrams for after they got destroyed through a short on the venier depth gauge. I email Sieg in China and the response was that they had no circuit diagrams.
    After I received the new set of boards (updated versions) I found that the front panel was displaying an error message. I then emailed them again, and in received the circuit diagram with the necessary procedure to remove the message.
    I have found that Sieg are very helpful in helping resolve any issues directly.
    Alex
    Jan 2005
    1695
    Thanks for posting it. It looks like the controller is based on a socketed Atmega8 processor. This makes it very suitable for software modification.
    Jun 2007
    3735
    Angry If...
    If you have the software, and if the chip is not read protected.
    Probably the only option WE have is to start from scratch. At least it could start to work in a properly defined manner.
    Jun 2007
    21
    Smile Should we Begin an Open Source Controller?
    Quote Originally Posted by neilw20 View Post
    Neil, now that is a fantastic idea. After lived through a month or so of torture getting my mill to work again (by the way thanks for you amazing help in this regard!) it would be good to have some control!
    Are you volunteering ;-)
    Jun 2007
    3735
    Cool Spread the word...
    Alex.
    Please spread the word. More input=more (read quicker success)
    I am trying...
    http://www.cnczone.com/forums/showthread.php?t=59118
    When we can solid tap, (and I mean solid) it is fixed. That's the target but I need all the circuit fragments etc every one has to make the job manageable.
    Neil
    Jan 2005
    1695
    Yes, the firmware would need to be rewritten. Duplicating the brushless DC speed servo functionality should not be excessively challenging.
    Mar 2008
    3655
    Would it be possible to control this motor directly with PWM from a Smooth Stepper? Would this still need firmware mods?
    http://warp9td.com/documentation/Smo...ManualV1.0.pdf
    CR.
    Jun 2007
    3735
    Yes, but...
    It won't work any better.
    The problem is in the motor control PCB.
    The break out board already creates a suitable control signal from the PWM signal from Mach3.
    The stupid firmware/hardware just pushes the front panel buttons like a human, trying to go faster, sh1t. too fast. slower, oops. I'm drunk, I forgot which way to go etc.
    When the PWM signal goes to zero and says, stop, it can't even push the stop button, (which is ignored if it is accelerating.)
    The software engineer was a moron and should not be allowed to touch this type of product.
    IT IS A SAFETY ISSUE
    Jul 2003
    62
    Hi Adel
    It looks like I have the same issue as you with the error with the new Boards
    What did you actually do to fix the error?
    Cheers
    Rob
  1. help with wiring diagram for C6 CNC
    By JDsto in forum Syil Products
    Last Post: 01-10-2008, 01:37 AM
  2. Wiring Diagram
    By SCHMEOW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2007, 05:40 AM
  3. need Eurospark 740 wiring diagram
    By kh_khayat in forum CNC Machine Related Electronics
    Last Post: 10-14-2006, 12:54 AM
  4. Control Box Wiring Diagram
    By bigvinney in forum CNC Machine Related Electronics
    Last Post: 01-22-2006, 11:57 PM
