587,180 active members*
4,584 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Wire Frame -2- Solid
    Sep 2006
    18
    I'm Imported a *.dxf File which come up as a complex wire frame. How Do I Create solid Surfaces on it so that I can switch back and forth between wire VIEW and SOLID VIEW?
    Mar 2005
    461
    First things first...
    1. What version of Mastercam ?
    2. If you press Screen Statistics, what entities are present ?
    If it is complex wireframe chances are the surface or solids are not importing in from the original cad system or the dxf converter will not bring them in. Try using a different importer, IGES out from original cad system and in to Mastercam then you shouldn't have to recreate the wheel.
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
  1. Frame Material
    By elogicca in forum DIY CNC Router Table Machines
    Last Post: 03-12-2006, 12:55 AM
  2. Replies: 8
    Last Post: 07-06-2005, 04:45 PM
  3. selecting wire frame or surface?
    By fastolds in forum Surfcam
    Last Post: 01-04-2005, 08:29 PM
  4. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
  5. cnc metal frame
    By georgebarr in forum Uncategorised MetalWorking Machines
    Last Post: 02-06-2004, 09:59 AM
