586,537 active members*
2,872 visitors online*
    Sep 2009
    68
    winDNC how to use it?!?
    Hi all,
    guys, please help the Fagor control and winDNC are new to me and I cant get them to work,
    I have a rs232 and Ethernet communication on the machine, I am only trying to send a program form my PC and execute it on the CNC, either from memory or I would prefer drip feed it.
    I menage to establish the Ethernet comunication but I dont know how to load a program in the winDNC I dot know what type of file should the program be how to be named (P0001 or what) or the extension (.nc .txt .fghjk or what) also I have no idea what should the program look like I am looking at the fagor manuals and all I see is the canned cycles or some programming examples for hand programing on the operators panel but I am using CAM software and I get ISO(G) code programs that I want to execute them.
    again please help I have 10 years experience with fanuc and siemens controls but I have never been stuck like this...
    any example or suggestion of how to operate would be deeply appreciated
    the control is Fagor 8055i(its a machining center) and I downloaded the WinDNC V5.2 software from the official web of Fagor automation.
    Dec 2009
    88
    Re: winDNC how to use it?!?
    why not use usb??
    if its a mill control then it needs to be .pim extion
    if you dont have a usb on the control there is one inside of it that u can plug an egtention cord to. i find the usb to be a lot user frendly
    Jul 2003
    1220
    If you want to transfer file to controller the file name needs to be six numbers. eg 000000.pim
    First line needs to be correct format. Post this line for a look..
  1. Fagor 8020ms with Windnc
    By arronpatton in forum Fagor Automation
    Last Post: 06-15-2018, 11:55 PM
  2. Fagor 8025TG and WinDNC
    By trentbosch in forum Fagor Automation
    Last Post: 04-18-2014, 06:09 AM
  3. Desesperado con WinDnc y UN Fagor
    By JLAM in forum Spanish
    Last Post: 06-12-2013, 01:51 AM
  4. WinDNC and Linux
    By dansmart in forum Fagor Automation
    Last Post: 11-15-2011, 04:21 AM
