587,543 active members*
4,048 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Will build a Benchtop mill including Castings! Comments appreciated.
Page 11 of 15 910111213
Results 201 to 220 of 300
  1. #201
    Nov 2005
    334
    some progress, MORE required!
    TOTALLYRC:
    Hope you haven't been faced with a similar Predicament!!
    Wizard:
    Have noticed you have been prowling around over in the RP Printer Forums,
    Thinking about taking the Plunge???
    ZipSnipe: Have been watching your thread with interest !!!
    Installed My “Ultra” Cross Slide on the “old” Fixture Mill.
    The prospect of having a Mill with both CNC and Manual capabilities
    is very appealing to me.
    However; to make this a viable solution the Head casting will have to be modified
    to attach the Z axis motor mounting bracket, the pinion gear shaft will require an extension
    for the belt drive pulley and the vertical column will require some machining to add an 8-10
    inch rack and pinion assy. to raise and lower the Head because the Quill travel is only 3 ¼ inches.
    Sounds like a lot of work...so.....Better get Busy!!
    w. Smith, Mission Viejo, CA
    Attached Thumbnails Attached Thumbnails Fixture Mill-4-22-13A.jpg   fixture Mill-4-22-13B.jpg   Fixture Mill-4-22-13C.jpg
  2. #202
    Feb 2006
    1187
    Looking good, yeah I was wondering how you would do the z axis. Keep up the good work!!!!
  3. #203
    Nov 2005
    334
    Teardown Begins
    ZipSnipe: The Z comes next
    The tear down of the Fixture Mill Head Assy has begun
    First the Motor & pulley, and then the top cover were removed.
    The 4 Cap screws capture the Spindle support bearing as well as the bottom cover
    because the head Casting is threaded.
    The Pinion Gear & shaft were removed which allowed the Quill and Spindle assy
    to slide free of the Head Casting.
    Now I can design the Stepper motor mounting brackets and the Bearing configuration
    to support the Pinion Shaft & its extensions.
    It's been many years since I assembled this stuff and I forgot how it was put together.
    However; the Quill - Spindle Assy with it's Timken Tapered Roller Bearings is off limits!!
    W. Smith, Mission Viejo, CA
    Attached Thumbnails Attached Thumbnails Motor & Covers Removed.jpg   Top Cover-Motor Assy Removed.jpg   Bottom Cover Removed.jpg   Quill-Spindle assy Removed.jpg
  4. #204
    Feb 2006
    1187
    Well Mr.Smith. looks like ur on the right track. I too will be tearing my milling head apart and it has been several years since I put it together. Seems like we are on similar paths with two different outcomes. Yours to make it cnc mill and mine to make it a better manual mill.
    May the shavings always be blue !!!!!
  5. #205
    May 2005
    3920
    Quote Originally Posted by CNCfun&games View Post
    TOTALLYRC:
    Wizard:
    RepRap? That maybe a different Wizard as I've not been frequent to any of the repRap forums recently. I've thought about it but I need to get myself a CNC mill first. Frankly trying to balance the demands of the house (a new roof real soon) and other expenses is significantly impacting my CNC plans. However I've been able to acquire some freebies that might lead to a PC board sized mill.
    Your thread is most interesting and considering the design of that fixture mill it would be ver versatile as both a manual and CNC mill. If I ever get the budget straight I might go for an all CNC machine myself.
    As always waiting on more pictures.
  6. #206
    Nov 2005
    334
    False Start!!
    The first task was to add a motor mounting plate to the left side of the head casting. A 1/2"
    aluminum plate with a couple of bevels, milling on the side provided an acceptable fit. Then both
    parts were drilled, reamed, and counter bored for the existing pinion shaft and double bearings.
    After machining the motor adapter block, the motor was attached and the assembly was placed
    on the head casting for a quick look. It became obvious that the motor should not be located
    that close to the work area. This will require moving the motor back behind the head casting.
    Another concept next time.
  7. #207
    Nov 2005
    334
    Concept 2 in work!
    Concept 2 utilizes a configuration which is similar to the one
    used on the Y axis of the Cross Slide for this Mill.
    The Motor is moved to a more convenient position with a set of pulley's and
    a cog belt.
    The location behind the head appears to be a much better solution......
    Covering the cog belt should be easy....more next time.
    W. Smith, Mission Viejo, CA.
  8. #208
    Feb 2006
    1187
    Looking good bud!!! Love seeing the progress. This is the z axis right?
  9. #209
    Nov 2005
    334
    Concept 2 ...not bad!!
    ZipSnipe:
    yes!.... this is the Z axis Mod.
    The motor placement seems to be OK.
    Now a little paint and I'll reinstall the Quill Assembly.
    The round colums look terrible....will have to break out the
    rust remover!!
    W.Smith, Mission Viejo,CA
  10. #210
    Nov 2005
    334
    Z axis Finished for now!
    Painted all the new parts, and assembled them without any problems.
    The handle only requires one full turn for full travel. Not sure if that's
    good or bad.....but time will tell.
    The column's cleaned up reasonably well with only a little elbow grease
    and some GOJO hand cleaner a friend told me about.
    Next comes the big job of moving the vertical column up & down with a Rack & Pinion.
    It's standard practice on drill presses....maybe I can obtain a Rack & Pinion Assy. "Ready Made".
    I'll check the Grizzly & ENCO Catalogs.... any help would be appreciated!!
  11. #211
    May 2005
    3920
    Gojo for cleaning up rust! Never heard of that one before.
    Junk yards might be a good place to scoop up an old drill press for parts. That is if you can find one that will even let you in.
  12. #212
    Nov 2005
    334
    So Far...So Good....Happy with Results!!
    Wizard: Use Scotch Brite as an applicator pad for the GOJO. It speds up the process.
    Found the R&P on Grizzly for $27.
    The 3Axis Fixture Mill will be ready to run with a couple of minor Additions.
    1.- fabricate a cover for the Y axis Drive assy on the Ultra Cross Slide which inc. the linear rails.
    2.- Install the Rack & Pinion on the vertical column.
    3.- Complete the Controller (ala microwave oven) with the Gecko G540 and the power supply
    in the enclosure with the Video Monitor.
    4.-I can use the first of the 3 controller enclosures for all 5 of the machines I have in work
    because the motors are all identical KE 23H2100-35-4B's.
    5.- The Standard Cross Slide will retain the stock dovetail Slides and is in work now.
    Hopefully I can show some real progress next time.
    Attached Thumbnails Attached Thumbnails Fixture Mill- 3 axis CNC.jpg   Fixture Mill- 3 Axis CNC-b2.jpg   Fixture Mill- 3 Axis CNC-b3.jpg
  13. #213
    May 2005
    3920
    Learn something new everyday! The problem at my age is remembering what I've learned.
    Nice progress as it is!
  14. #214
    Nov 2005
    334
    Pattern Making Detour!!
    It has been awhile since my last post but thought those of you have an interest in Pattern Making
    might find some interest in my latest “adventure”.
    The Project consists of the fabrication of a fairly large match plate Pattern with two cores which
    provide the weight savers necessary to keep the raw casting weight down to about 130 lbs.
    This is by far the largest and most complex part I have undertaken and posed some unique problems.
    The first four pictures show general construction details,pic 5 shows that the pattern halves must match
    perfectly before being attached to the "Match Plate".
  15. #215
    May 2005
    3920
    Good to here from you again! How did you make out with your mills?
    I'd comment on the pictures except for the fact that I haven't been able to open any attachments on any threads today. That being said what is it?
  16. #216
    Nov 2005
    334
    Pattern Progress
    Wizard : Always enjoy your comments……Keep them coming!!
    FannBlade: thanks for the vote of confidence!!
    This time the basic Patterns will be attached to the Match Plate shown in Pic #1
    of the last post.
    To Digress: a word about pictures 5 & 6 Shown on my last post.
    Pic 5 shows the two pattern halves joined together. This step is necessary
    to sand any high spots or fill any low spots to insure that the patterns match perfectly.
    Pic 6 shows the sanding sealer and the rubber sanding blocks used to provide smooth, flat
    Surfaces.
    These last two pictures also define the basic shape of the “SPINDLE HOUSING”.
    Now this week’s post:
    One of the long edges of the match plate was run thru the Jointer and identified with an arrowhead
    on the centerline, and all critical dimensions are taken from that point.
    After carefully measuring the pattern halves, the outlines were traced onto the match plate.
    Then side one was glued to the match plate. Then the core supports were added.
    Core supports are painted black for identification.
    Next time: the core boxes will have to be carefully fabricated , and fitting confirmed.
  17. #217
    Nov 2005
    334
    CORE BOX CONSTRUCTION
    This time the work will be to fabricate two core boxes.
    These boxes will locate the openings in the casting for mounting the spindle and
    the access chamber for belt mounting and adjustment.
    Core box #1 consists of one symmetrical cavity which can be used for both halves
    of the spindle core. Pic #2 shows the basic spindle core ready for placement in the core box for
    finishing.
    Core box #2 is much larger and more complicated because it will create two mirror image cores.
    This will be apparent when the castings are available for viewing.
    Most interior surfaces formed by core #2 will have 15 degree draft for easy removal from the core boxes
    And should also make for a nice appearing finished Casting. Pic#5 shows the core box ready for many coats of sanding sealer and block sanding.
    I hope I’m not being too optimistic, because there is a lot of time and material resources wrapped
    up in this process!!
  18. #218
    Nov 2005
    334
    Largest Pattern so Far...Ready to Go!!
    Matchplate completed ???
    The enclosed pictures show the completed configuration of the Matchplate.
    It was placed on a temporary stand which supports and protects it
    while the block sanding and finishing is finalized .
    This was a very challenging part of the whole process. Great care was taken to
    Properly locate the core supports to align the two cavities in the casting.
    The next step will be to drop the pattern & core boxes off at the foundry.
    Two test samples will be produced to “ proof” the design & approve
    the new company selected to pour the castings.
    Expect next week will be a REAL nail biter!
    W. Smith Mission Viejo, CA
  19. #219
    May 2005
    3920
    You have some nice work here! OK now I know this is a spindle housing but for what? It looks like the housing will have a bore for an awfully big spindle so I'm assuming this isn't for the other machine you have recently work on and reported here.
    I could imagine that being a big challenge. My background is more in die casting so I have to ask are the molds mounted permanently to the match plate? I could see where that might be a problem on bigger patterns but would think it would be easier for smaller items.
    You have more than one foundry locally? That is a shock right there.
    Will be waiting for the pictures.
  20. #220
    Jun 2011
    695
    Looking forward to the results!
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  1. Convert a 2 axis Cross Slide to CNC-comments appreciated!
    By CNCfun&games in forum Benchtop Machines
    Last Post: 10-25-2017, 06:21 PM
  2. Will Build a Moving Gantry ROUTER-comments appreciated.
    By CNCfun&games in forum CNC Wood Router Project Log
    Last Post: 12-25-2016, 01:06 AM
  3. DIY benchtop mill build
    By mkuivamaki in forum Benchtop Machines
    Last Post: 03-19-2014, 08:54 AM
  4. Designed from the ground up - including castings
    By Hack in forum Vertical Mill, Lathe Project Log
    Last Post: 02-09-2012, 11:09 PM
