587,272 active members*
5,109 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Wich are the best filler for Epoxy?
Results 1 to 8 of 8
    Mar 2005
    269
    Hey guys, i was reading some nice posts about machines made from Epoxy and fillers like sand.
    I found that is possible to use calcium carbonate, dolomite, sand...
    Someone know wich will be the best combination to make an solid and not overweght machine using epoxy+fillers?
    Thanks in advance
    35538
    Re: Wich are the best filler for Epoxy?
    A few threads down, is a thread with 5000 posts which explains exactly what fillers to use, and in what ratios.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2016
    12
    thanks
    Mar 2005
    269
    Thanks too much gerry. i read some of these posts a few days ago, will read it full this time!
    Sep 2012
    108
    The aggragtes and fines used in concrete (cement) can be used in epoxy granit. Large stones 10-15mm down to fine sands graded to fill the voides. Sharpe stones add strength but make it harder to mix and work. Density is around 2200kg/m3 less than aluminium.
    Mar 2014
    1131
    There are some different stones that can be used(?) in my area. These are;
    - Quartz sand:
    - A sand that is called "Silis" in Turkish. People use it on sand blasting.
    - Lastly some kind of black sand. It is used to decorate floor of aquarium/fish tanks.
    Would you use these as filler?
    May 2015
    34
    I used two grades of quartz sand, and biggest aggregate was something like on your second photo, river sand. 8% to 10% slow curing epoxy, not vibrated, hand compacted with tools, and eveyrthing went well. Got the density of almost exactly 2 kg per cubic dm. Make sure to dry it well, as some bagged quartz can be little wet.
    Oct 2016
    16
    Basalt is the hardest and should be the best option, i think. The weight should also be a benefit. However, i could not find basalt in all grain sizes, thats why i mixed basalt, marble, gravel and quartz sand.
  1. Need advice on filler/paint
    By Cheff in forum Momus Design CNC plans
    Last Post: 07-27-2013, 01:46 AM
  2. Filler Rod for Tombstone Project?
    By Kincade in forum Welding Brazing Soldering Sealing
    Last Post: 07-26-2013, 06:20 PM
  3. Two questions, bits and filler
    By Buzz239 in forum Engraving Machines
    Last Post: 11-06-2012, 12:53 PM
  4. 8020 Extrusions with Epoxy Granite filler?
    By reiyuki in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 02-12-2010, 09:10 AM
  5. Filler Rod for 4130?
    By Chris64 in forum Welding Brazing Soldering Sealing
    Last Post: 09-30-2007, 06:01 AM
