587,569 active members*
3,552 visitors online*
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Oct 2006
    60
    Tool makers vice... 100% I have 3 and if used correctly like said before, will hold any d.o.c my modded Taig can handle . all the Kurt and Kurt like vices are to large.. even the 3" clone from china.
  2. #22
    Oct 2007
    29
    Taig vise
    I buy from Enco, CDCO Tools, ebay. Info links, here, from my site. cheers! Alan
    Micro-Machine-Shop.com
    Taig Micro Mill Screwless Vises
    Vises
    Alan
  3. #23
    Nov 2012
    23
    I ended up purchasing this clamp: Vise, 3" Screwless, with Hold Down Clamps - LittleMachineShop.com
  4. #24
    Oct 2007
    29
    vise
    Yes that is a good one. The "toe clamps" may cover holes you need to get to in order to adjust the vise opening, though. regards, Alan
    Alan
  5. #25
    Nov 2012
    23
    Quote Originally Posted by SpeedsCustom View Post
    I can't see the page with the number.
    Get a Toolmakers Precision Vise, thats what there called. Got mine on Ebay for 50.00!!!!
    -Jason
    Jason,
    Can you provide some additional info for how you attached the clamp to the table?
  6. #26
    Jul 2006
    525
    For a taig, I think most every vise available is too large, and absorbs too much Z axis travel. They also make bad utilization of what is actually a fairly large table. A 4" vise will leave you with roughly a 4"x3" area to clamp your work piece, and nearly 6" on either side of that which you virtually cant make use of, because the vise is in the way.
    This was my solution, and I have to say its worked out incredibly well. I'm not sure what this forums vending policy is-- i'm not currently selling these, but the thought has crossed my mind.
    [ame=http://www.youtube.com/watch?v=_pmFsAxRvWI]T-Slot Vise Jaws - YouTube[/ame]
  7. #27
    Apr 2004
    5749
    That's pretty clever, Dockwood.
    But I'm a little unclear as to what's going on, exactly. It's hard to tell from the video, but it looks like the jaws are aluminum, pushed by the black steel parts that exert the force. Is that correct? Or is the force only applied at the top of the jaw? I think it's better to have the steel contact the workpiece, unless it's desirable to prevent marring, in which case one can slip something in there.
    If you decide to sell these things, how much would you have to get for them?
    Andrew Werby
    www.computersculpture.com
  8. #28
    Jul 2006
    525
    Quote Originally Posted by awerby View Post
    Andrew Werby
    ComputerSculpture.com ? Home Page for Discount Hardware & Software
    The aluminum jaws bolt to the tables t-slots. The steel pieces provide all of the clamping force on the workpiece.
    On the "movable jaw" only the steel piece contacts the material (atleast in a clamping manor.) On the fixed jaw (left side) the entire jaw is aluminum, so yes, the work piece is in contact with an aluminum soft jaw.
    I had initially thought this might be an issue, so I had designed a second set with a bolt-on steel section. I also made a second fixed jaw, in case it was an issue.
    So far, it hasn't been-- I rarely work on steel in this machine, so the workpiece is almost always of the same hardness or less. If rough sawn steel were to be run, i'd likely mill flat the section that would contact the soft jaw, to avoid point loading that could cause issues. I think generally, there is enough surface area where it doesnt cause an issue.
    For what its worth, I work full time as a machinist, and regularly use aluminum step jaws on rather hard steels. They hold up better than you would possibly imagine..
    as for cost-- i'll have to get back to you on that one
  9. #29
    Nov 2012
    23
    Quote Originally Posted by rlockwood View Post
    Light weight, not like some of the other vises I have that drain "X" axis movement. Nice work and clean design.
  10. #30
    Apr 2007
    327
    I'm interested in your vise, if you decide to make and sell them. I sent a pm with my email.
    Thanks,
    Gary
  11. #31
    Feb 2013
    0
    Is that steel finger just a square steel piece with a countersink in it? so tightening the part just centers it and so pushes sideways or is it something else?
  12. #32
    Jul 2006
    525
    Quote Originally Posted by Sups View Post
    Yes, it is a steel block-- countersunk on both sides, and it sits on a conical wedge. Tightening it forces it to center on the two cones, and causes a "downwards and forwards" motion. One side is serrated, the other is smooth. The clamps themselves are produced by Carr-lane, and unfortunately they hold (and enforce) patents on the design. Search for "Carr-lane tiny-vise" for more information.
    For what its worth, I have decided to make a few sets of the vises. If you're interested, feel free to send me a PM. Otherwise, i'll likely make my own thread in a couple of days, when some work has been completed.
    I wont be producing the Carr-lane portion, but will purchase a few from them, and re-sell them at cost.
    Rob Lockwood
  13. #33
    Feb 2013
    0
    Rob Lockwood
    I was more looking for the function of how it works. I am still far from getting a CNC of my own for personal uses, but the idea was quite interesting for fixture designs at my work.
Page 2 of 2 12
  1. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills / Lathes
    Last Post: 09-19-2017, 04:38 PM
  2. TM-1 vise
    By maxine in forum Haas Mills
    Last Post: 10-20-2007, 12:34 AM
  3. Home Made Vise Stop - For 6" Kurt Vise
    By widgitmaster in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2006, 03:49 PM
  4. cheap DIY low profile "softjaws" vise for TAIG
    By Smertrios in forum Taig Mills / Lathes
    Last Post: 04-29-2006, 06:20 AM
  5. Vise Recommendation
    By edge in forum Uncategorised MetalWorking Machines
    Last Post: 02-29-2004, 08:24 AM
