Hello,
I'd like to know what Servos & gearing I should use on my system. I am fairly certain that I will use the 400W 4-axis system they sell, but I may sway to another setup if the community insists on an alternative.
Firstly, the machine is a CNC router, with a moving gantry design. The gantry moves along THK 20mm Linear rails, with a total weight of approximately 80kg. Module 1 gear rack is used as the drive mechanism for the X and Y, with the gear PCD being 30mm. 1 rotation of the output drive corresponds to 94mm of linear movement.
The Z-axis of the machine has a travel of 200mm, and the moving portion (for which the servo will have to move) is approximately 20kg. This is mounted on THK 25mm Linear rails, with a 16mm diameter ballscrew of pitch 5mm.
My question is the following: What gear reduction would be required of the DMM-Tech motors to A) move the Z axis at an acceptable acceleration/speed without an additional lift assist mechanism, and B) Rapids of ~20,000mm/min (800IPM in imperial), on the X and Y axis.
I am reasonably certain that steppers would be adequate for what I require of the machine - but with some of the jobs that are required of it, missing any steps would be a catastrophe. The noise level is also likely to be unacceptable for me.
I have asked the same question of DMM-tech, but I have not received a response as of yet.
Many regards from Australia,
Lindsay
