587,517 active members*
3,041 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Which Router bits to Use
Results 1 to 8 of 8
    Aug 2004
    3215
    Does anyone have a chart (preferably with bit pictures) of what bits, size and shape, to use with what wood for desired results.
    Such as:
    1. picture engraving.
    2. letter engraving.
    3. cutout parts.
    and so on, i know this is general question and many senerios, but a simple guide would help new members to know which bits to try to buy.
    Maybe a standard set to put together like the most common used.
    Thanks, Joe
    Feb 2006
    213
    Quote Originally Posted by joecnc2006 View Post
    Such as:
    3. cutout parts.
    Thanks, Joe
    Joe I think there is a file in the yahoo hobbycnc page regarding cnc model aircraft. I just foraged around a bit and located the source he uses .try http://www.thinktink.com. for special bits...regards mike hide
    Apr 2006
    187
    Joe, if you want to PM me I have something interesting for regarding this thread.
    Jul 2008
    55
    I would be interested in this type of list.
    Jul 2005
    62
    I too would like a list of what others are using. So far its trial and error and more errors than I would like others to know.
    Terry
    Feb 2006
    213
    what exactly is a compression bit. I am assuming a upcut bit gives a clean top cut and a downcut bit a clean bottom cut. mjh
    Nov 2006
    303
    Quote Originally Posted by mike hide View Post
    You got the right idea. Just backwards. The down sheer is on the top and the up on the bottom.
    Sep 2010
    0
    I'm new to this and would like to do some engraving in MDF and PLYWOOD, I've seen carbide bit on ebay eg: 1/4" 20degree 0.1mm all the way to 90degree 2mm.
    are these what I should use for picture engraving or am I wasting my time and should be using something else?
  1. Router Bits in OZ
    By Exelanoz in forum Australia, New Zealand Club House
    Last Post: 11-18-2005, 03:41 AM
  2. Extra long router bits
    By whiteriver in forum Material Machining Solutions
    Last Post: 06-06-2005, 09:21 PM
  3. Stop Bits, Parity
    By gar in forum Computers / Desktops / Networking
    Last Post: 06-04-2005, 08:10 PM
  4. looking for Long router bits supplier in UK.
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 10-12-2004, 12:36 AM
  5. Router bits. ( Aluminium veneer )
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 05-12-2004, 04:49 PM
