Originally Posted by
hanermo
This advice below is wrong -- for Mach3.
Open Mach3, plugin control, pokeys plugin settings, pick the device, click configure.
One of the pages is pulse engine settings.
As per the docs above, it refers to the several versions of pokeys hw that were developed.
I have an original Pokeys usb and,
also have/use the pokeys enet with cnc addon,
that then later became the current pokeys cnc all-in-one board.
My pokeys Enet57 + cnc add-on drives a full-size scratch-built large VMC.
About 2400 kg, 1600 mm wide table, 2.2 kW VFD and ISO30 spindle, ATC, 32 mm ballscrews, 35 mm linear guides, Ac brushless servos.
To the OP:
IF You take it step by step, I can guide You to make it work.
1.
Can you connect to the pokeys from Mach3 ?
Is the plugin installed ?
