587,442 active members*
3,184 visitors online*
Results 1 to 8 of 8
    Jun 2003
    453
    Where to buy wire rope by the meter? (Australia)
    Hi guys,
    I'm trying to overcome an issue of the gantry yawing caused buy the gantry being too wide for the centerally mounted leadscrew. I think the easiest way I could overcome this is by running a cable system in a figure 8 layout with pulleys inside each corner below the table and the cables secured to the cross member which runs under the table (what the leadscrew nut is mounted to).
    I've only had a quick look on the net to try and find a supplier of wire rope who sells by the meter but all I have found so far is supplier who sell by the roll (hundreds of meters). I really only need about 7 meters of rope and the diameter shouldn't need to be any more than about 3mm.
    Anyone know where I might get this? I'm in Geelong by the way.
    Cheers
    Splint
    Dec 2004
    411
    Hi Splint
    Bunnings !!!
    I bought some recently as I had to winch a Coonara up the hill to the shed.
    I purchased a fixed length of 10 metres but I'm sure they also sell off the reel.
    Andy
    PS ......Sorry couldn't make the bbq.... new z axis almost finished ..... am pleased with it....hope you are well...Andy
    Drat, imperfection has finally stopped working!!
    Jun 2003
    453
    Thanks Andy, I'll go have a look. Yeah, it's a shame you couldn't make it along to the BBQ, it was a raging success. Maybe next time.
    Cheers
    Splint
    Aug 2007
    2
    Hi Splint
    Try A Noble and Son if you want top quality
    Macca
    May 2006
    1469
    Also one of the marine suppliers. Where they have yacht fittings.
    They will have cable. Mostly stainless I think.
    Greg
    Oct 2005
    8
    Wink
    failing all else, try your nearest airport.
    light aircraft or sailplane/glider use exremely flexible high-tensile wire
    if you don't want to go there, try "picture wire" from picture framers' supplies
    Feb 2004
    2337
    Dave, you know the SS stuff I have around my balcony? I have half a roll left over. When you come over for the other reason, you can also have some of that too.
    Dec 2005
    1408
    Failing all else, shopfitting people use the stuff for hanging shelves, lights and display boards.
    My best guess is that the marine people will be the easiest place to get it...unless you live in Alice Springs....
    Best wishes
    Martin
  1. Help With Dc Load Meter Led
    By dannystooblue in forum CNC Machine Related Electronics
    Last Post: 02-09-2017, 06:03 PM
  2. Arrhhhhghgh!!!!! I am at the end of my rope!
    By CoolHand in forum Hard / High Speed Machining
    Last Post: 12-06-2007, 04:17 AM
  3. How To Bore 1 Meter Pipe
    By sanjiv in forum Uncategorised MetalWorking Machines
    Last Post: 05-22-2007, 03:25 PM
  4. flow meter
    By larry53 in forum Welding Brazing Soldering Sealing
    Last Post: 03-12-2007, 09:24 PM
  5. Spindle load meter ?
    By Ken_Shea in forum Haas Mills
    Last Post: 10-11-2004, 04:21 AM
