587,415 active members*
3,579 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Videos > Whats the diffrent 3 axis and 5 axis programs
Results 1 to 5 of 5
    Jan 2016
    11
    Re: Whats the diffrent 3 axis and 5 axis programs
    Quote Originally Posted by asmanss View Post
    I've watched the video. It showed the simulated differences in movement but there wasn't any explanation of the pro and cons of one versus the other. Neither as voice over nor as text on the screen. There was a small box with text but it was almost unreadable and didn't provide any really useful info.
    The 3-axis version used a lot of the tool (bottom, sides, etc.), moving the spindle in a raster pattern with the workpiece in a fixed, flat orientation. On the other hand, the 5-axis version moved the workpiece around, rotating it through all kind of contortions to force the bit to only touch the workpiece on one small tangent location on the bit as the spindle followed the raster pattern.
    What exactly is supposed to be the benefit of doing all that extra movement and avoiding using the rest of the available bit cutting surface? Is it just to maintain a constant load on the spindle? Does it provide a better surface finish?
    Jonathan
    Sent from my SM-P900 using Tapatalk
    Hi Jonath this is just 2 program.and i purposed multi axis operation high tilted.because people must see diffrense.do you use 5 axis program.
    Jan 2016
    11
    No. I am still in the process of building my cnc router. I was just trying to understand the advantage here and the video didn't really help.
    Jonathan
    Congratulations your new router.theese videos just show.and i have company training 5 axis programs and model prototype.if you need a post settings and training my company will ready
    URS PROACTIVE DESIGN
    [email protected]
  1. Whats the best ratio for 4th axis
    By Georgie in forum Linear and Rotary Motion
    Last Post: 08-28-2018, 01:31 AM
  2. Need help 5-Axis router programs
    By n5zhm in forum Mastercam
    Last Post: 03-11-2013, 02:40 PM
  3. diffrent x axis problem
    By hornby chopper in forum Novakon
    Last Post: 08-10-2011, 08:54 PM
  4. 5 Axis Programs
    By leepez in forum Dolphin CAD/CAM
    Last Post: 02-13-2009, 07:45 PM
  5. posting as two diffrent programs?
    By manuelc149 in forum Mastercam
    Last Post: 11-01-2008, 06:56 PM
