I'm trying to cut out letters they range from 1/2 to 1", I'm using high performance vinyl it's 2mils thick and I'm having a hard time weeding it, should I be using something thicker?
What purpose list your set up what equipment are you using bit etc more info you give better chance I will have to help you....
As a signmaker myself, any letters that small are hard to weed. BUT, make sure your plotter is set to cut slow, and deep if it's hard to weed. High performance is the easiest vinyl to weed, I would suggest staying with that.
