587,787 active members*
2,242 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > what size motors for cutting photo mount board
Results 1 to 5 of 5
    Dec 2010
    0
    I was at a photo trade show today (one of my other money-pits is photography)
    one of the stands was showing a CNC photo mount cutter (now that's a neat idea I thought)
    popped in to take a look
    now the table size was about 4 feet square
    remember this is cutting photo mounts out of 1/8" thick cardboard
    the X and Y axes were belt driven, but the steppers were humungous
    must have been 4" square and 8" long
    now I now it had a fair rapids speed (6 feet per second I think the nice lady said) but are motors that big slight over kill or what?!?
    whileI was watching it was fast, but I would doubt 6 feet per second, maybe 2 at best
    Jul 2005
    16
    They were Nema 34 sized motors probably something in the range of 4-8 newton
    I was probably at the same show as you and came away with the same idea as you as I hate cutting mounts. I've pretty much designed my machine with the exception of the mechanism that is required to drive the blade in at an angle, need to give that some more thought
    Dec 2010
    0
    the other thing I noticed is that they were cutting the back of the mount
    I would have thought that made getting the corner bevels right very difficult?
    I wondered about using a stepper to rotate the knife blade, that way you could set any arbitrary angle
    Software would have to make sure the angle was the sam as the direction of travel
    Also have to take into account bevel, so there's a compound angle going on
    hence my query about the corners
    where you based btw?
    I'm in Leighton Buzzard
    are you aware of the Talk Photography froum, I loiter there sometimes as well
    Jul 2005
    16
    They cut from the back as it avoids marking or damaging the face of the mount either by the cutting head or the clamps that hold the card flat.
    My manual mount cutter works in the same way and it is pretty accurate and easy, any slight overcuts are not noticable but this can be very finely tuned in cnc, the angle of the blade never changes during a cut so it can be in a fixed holder. I'm planning to have utilise different holders for different blade angles, 45 and 90 degrees initially for angles and staright cuts, ie trimming edges. The cutting head will need to leave the card and reinsert at 90 degrees for the corners.
    I'm based near Cambridge, I post on talk photography too under the username 'Hairyduck', thought I recognised your username from somewhere
    I've also had a brain wave about the cutting head and recon I'm ready to start building a concept for that, as soon as I can make any space in the garage
    Dec 2010
    0
    when you're ready - I'd love to see the brain wave!
  1. PHOTO LIMIT & HOME BOARD-C16
    By diyengineer in forum Open Source CNC Machine Designs
    Last Post: 12-10-2010, 09:39 AM
  2. What size motors for cutting out guitars?
    By NewDay in forum DIY CNC Router Table Machines
    Last Post: 04-16-2009, 11:47 PM
  3. Photo sensative circuit board
    By Ayjay in forum CNC Machine Related Electronics
    Last Post: 07-30-2006, 04:50 PM
  4. Ballnut mount screw size
    By ViperTX in forum Linear and Rotary Motion
    Last Post: 09-30-2005, 04:21 AM
  5. Stepper motors I got cheap ??? photo
    By Stevie in forum CNC Machine Related Electronics
    Last Post: 02-15-2004, 01:57 PM
