I've been searching and was hoping someone had already answered this one specifically but did not find it.
I have a https://www.amazon.com/gp/product/B09Z8VBQSS?th=1 VFD and a water cooled ER20 3kw 220V 10A 400Hz Spindle and want to add a braking resistor.
Yesterday I cutting new fixture holes in my spoilboard I hit a bolt I thought I had accounted for. It stalled the spindle as it broke off the carbide bit. On my old undersized VFD this would error but a power cycle would fix it.
With this VFD it threw an Err01 and power cycling would clear the error but hitting start on the spindle caused it immediately. Disconnecting the spindle and programing the VFD so I could run it from the front panel causes it to click and Err01 instantly when I hit run so I am pretty sure this caused an IGBT failure so I guess I'm replacing this drive.
It looks like if I had had a braking resistor this could have saved the VFD but I am not mathematically gifted enough to figure out which one.
I am pretty sure I need at least a 22ohm resistor but after that I'm lost. Is bigger better on the watts? https://www.amazon.com/Xiaoyztan-Wir...1zcF9hdGY&th=1
