587,465 active members*
2,956 visitors online*
Results 1 to 20 of 20
    Mar 2004
    43
    What programs can do this-
    IM looking for a program that can take a picture and turn it into a drawing of plotted dots(I forgot the name the type of drawing) and save it as a format that I can put into a cam program, or maybe make the g-code in the same program.
    Im sure theres something simple out there for this.
    Jun 2003
    453
    Do a search for raster to vector.
    May 2004
    350
    Are you referring to stimpling? If so DrMetza is what you need
    Dec 2004
    518
    Not really sure what you want. I took Paint Shp Pro and a stock picture and did a greyscale half-tone conversion. Finally I reduced that to 2-bit color depth. Is this what you were thinking?
    Evodyne
    Attached Thumbnails Attached Thumbnails truck.jpg   truckhalftone.jpg   truckhalftone2bit.jpg
    Mar 2004
    43
    Evodyne- Pretty much like that, but with all the dots a consistant diameter. I was messing with some programs and did and came out with the same sort of thing, but its not exactly what I wanted.
    aksess- i will check out that program
    Mar 2004
    43
    aksess do you have a link?
    Jul 2005
    12177
    I think what you are looking for is something that can take a picture and turn it into a mesotint. I think that is the correct term; it is a black and white version of pointilism where the grey scale in an image is obtained from the density of blacks dots all the same size. I do not know of anything comercially available to do this.
    May 2004
    290
    Quote Originally Posted by Geof
    Hey Geof,
    I think he's looking for a halftone, or at least that's what its called in screen printing. The following are examples...
    http://pages.cpsc.ucalgary.ca/~mirtc...r/halftone.gif
    http://www.ccsn.nevada.edu/cg/kanet/...one_screen.htm
    You can do it in Photoshop (I use 6.0). Image->Mode->Bitmap. Then choose halftone from the drop down. Just make sure you first convert your image to grayscale. You can then specify size shape and frequency of your "dots". Then it will need to be converted to vector, unless your CAM can read raster.
    Good luck!
    Carlo
    Jan 2005
    7
    If you just want to reduce a picure to fine dots, just use a standard program
    like PhotoShop. There are Mezzotint filters one can use or play around
    with diffusion dithering in the program. all the best.
    Mar 2004
    43
    Ok, I got some ok results with the halftone, so how would I get the points compatable with a cam?
    May 2004
    290
    Quote Originally Posted by july_favre
    You can save your work as a TIF, JPG, GIF or other raster file. You'll then need to convert this to a Vector file (DWG, DXF etc). You will need a raster to vector converter to do this. Try searching for a demo or shareware.
    Realize that in doing so, you will essentially be creating outlines of your half tone dots. These outlines will then become the tool paths in your CAM file.
    Carlo
    Feb 2005
    78
    G'day
    See my avatar. I Got a photo from the net and processed it in PotoShop and saved it as AutoCad 14, opened in ACad and saved it as DXF, then opened it in Mastercam 8, got the toolpath and nc file from it. It took me many months and many software programs as well as hours and long nights to get there. What I can tell you. If you want to do some venturing into this mater you will need the tools. There is not a magic wand.
    Good luck
    John
    Feb 2005
    78
    l
    Aug 2003
    327
    Hi Old John,
    I see you are from Aus. Have you been on the Aus forum and contacted us guys. Where do you live?
    Question on your post.
    Does phoptoshop save the format as a vector file for autocad, or do you use autocad to complete the vectoring?
    Is mastercam the better CAD/CAM software that you found would process the DXF file, what about Mach3??
    /Michael
    Feb 2005
    78
    Quote Originally Posted by mikie
    Hi Old John,
    /Michael
    G'day
    Q1 No. Ihave not. I'll visit the forum. I live in Sydney.
    I must apologize to everyone for misleading you about PhotoShop. The program i used to create the file from a photo was "Corel 10". My apologies to all.
    In Corel 10 you can create contour vector. To do the hatching-like file I cannot find my notes and I have the program uninstalled, so I cannot check.
    Once you have the file in Corell10 save it as DWG ACad R 14, open It in ACad 14 and convert it to DXF. Then it can be opened in MCam and generate a toolpath.
    I m attaching two files produced that way.
    I'm sorry for the mistake.
    John
    Aug 2004
    2849
    Looks like a pic of Che Guerra (I think that is how you spell the last name...).
    Apr 2003
    372
    You can import a photo and create the toolpath, all in the one package by using DeskCNC, you have an option of either 3-D depth carving based on greyscale tones or a 2-D raster to vector, you can download it and try it for 30 Days, it is well priced too.
    you can download it from www.deskcnc.com
    Hope this helps
    "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
    Greetings From Down Under
    Dave Drain
    Akela Australia Pty. Ltd.
    Feb 2005
    78
    Quote Originally Posted by ViperTX
    His name was "Ernesto Che Guevara" and the "u" is silent in Guevara.
    John
    Sep 2003
    111
    VS3D produces the highest-quality relief surfaces from digital images, and it will output the G-Code for various cutting strategies as well.
    As previously mentioned, converting gray-scale values into a continous relief surface for smooth carving is one possibility. Here is a tutorial showing how to do that in VS3D: http://www.designscomputed.com/vs3d/...mg_emboss.html
    Another technique is to take a coated material - like black anodized aluminum, for example. Using a V-bit, run a "peck" tool path such that the depth of each individual peck is determined by the brightness of the image at that point (brighter "pixels" are pecked deeper). Since the V-bit reveals more bright aluminum the deeper it goes, the end result is that the final piece looks like a half-tone image. VS3D can apply this technique as well.
    If anyone would like to give it a try, VS3D is available for free 30-day full-functioning trials. I can also supply additional specific help/instructions, if needed.
    The VS3D home page is located here:
    Daniel Carr - President,
    Designs Computed, LLC
    Aug 2004
    48
    Have you checked out this program http://www.imagecarve.com/index.html
