Hi Guys
Could somebody please explain what it is?
Why do I need it with Steppers / Geckos?
Where does it sit?
How do I use it?
Is it easy to build?
How do I source materials?
What are the good reference threads?
Andy
Hi Guys
Where does it sit?
How do I use it?
Andy
A breakout board usually plugs directly into the parallel port, and has screw terminals for all the parallel port pins. This makes it very easy to wire your Geckos.
They also usually have provisions for limit and home switches, including onboard power and pull up resistors. So all you have to do is wire your switches to the breakout board and you're ready to go.
You don't have to use one, but they make wiring your system a lot easier.
When you can get one for $25, I see no reason to try to build your own. http://www.cnc4pc.com
Other popular boards are available at http://www.campbelldesigns.com and http://www.pmdx.com
prices and features vary
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Thanks Gerry
Better go to work now ... enjoy your evening.
Andy
