587,468 active members*
3,036 visitors online*
Results 1 to 4 of 4
    May 2010
    23
    What is better option between glass and RF laser tube
    Hi all,
    Firstly, thank you all for your help on my birch plywood post, your help has been invaluable.
    My next question is...
    If you had a choice between a 50Watt red type (?) glass laser and a 70Watt RF Coherent laser to go in a machine that you will be using to cut 4mm birch plywood, what would be the better option?
    (Lens options and air assist will be used included for both options)
    Thanks in advance !!
    Jul 2008
    776
    Ask Gary [email protected] (or me )) about GCC X380/X500 with Spectron laser. PM me your e-mail - I will send you some information.
    And do not forget that you can upgrade Spectron to Synrad!
    Feb 2005
    124
    They told me the lifespan of glass lasers is about 1500 hours and the lifespan of a RF laser is about 10k hours. Refilling or buying a new RF tube is way more expensive than a glass tube on the other hand..
    Jul 2008
    776
    Lifespan of glass tube very often ended during transportation
  1. Glass Tube Connection
    By MonoNeuron in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 10-02-2014, 04:08 AM
  2. GoldenLaser and 150W laser glass or steel
    By franc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-13-2011, 08:18 AM
  3. Laser cutting glass
    By westland in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-06-2009, 06:02 PM
  4. Laser Cutting Glass
    By Mcyoda in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-12-2008, 04:55 PM
  5. Laser Cutting Glass
    By boxxer_boy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2007, 03:05 AM
