587,415 active members*
3,579 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > What is the best type of aluminum for CNC machining?
Results 1 to 2 of 2
    Sep 2013
    2
    In North America the standard economical / strength type is 6061, while in Europe it's 6082.
    How are they compared to 6060?
    My friend purchased 6060 for a project, but I would have preferred 6061/6082 because 6060 is 2/3 the strength.
    He said he tried cutting 6060 and he thought it was better with his CNC machine.
    But I read on a few threads here recommending 6061 over 6060.
    I also read that anodizing with 6060 is better, but I don't mind so much the results I'm getting for anodizing 6082.
    Oct 2012
    179
    Re: What is the best type of aluminum for CNC machining?
    Depends on what you are making. Lubrication is the key to getting it to cut without welding chips to the bit. Softer materials seem to weld chips and do not machine well. Too slow a feed/speed rate will create the welding problems as well. Get a good feed/speed calculator. Guessing is expensive both in tooling and material.
    Bob
  1. What type of Machining Can you do with...
    By khowrad2188 in forum MetalWork Discussion
    Last Post: 02-24-2013, 11:31 PM
  2. Machining type
    By sml2010 in forum Material Machining Solutions
    Last Post: 11-11-2011, 04:50 PM
  3. What type of drill bit to use for aluminum?
    By shotgunn in forum Want To Buy...Need help!
    Last Post: 06-09-2010, 04:11 PM
  4. Determining aluminum alloy type
    By bdrmachine in forum MetalWork Discussion
    Last Post: 12-13-2006, 03:22 AM
  5. Type of Aluminum??
    By cbcnc in forum Uncategorised MetalWorking Machines
    Last Post: 06-18-2003, 03:37 PM
