Hello,
I ran into a program the other day on a Doosan VMC with a FANUC 0i controller That helically interpolated a hole. It compensated for the diameter programmatically (the diameter offset was set to zero). I've seen this when using CAM software but never when using Manual G-code entry (which is what this shop uses) I have two questions about this.
1. If you don't use the diameter offset can you still use the wear offset? seems like you would get something with a negative diameter if you tried. Wouldn't that cause an error?
2. Why would someone do this rather than just program it at the right diameter and use G41/G42?
I apologize if this is a silly question.
Thanks for your time.
