An older Fadal with a mechanical(motor driven) waylube pump.
The motor seems to turn(very slowly as designed, but the gears don't.
Does any know of a replacement pump or upgrade for this design pump. thanks.
You can call the factory or Devco with the part number and model number and get a replacement. The pump should have a tag on it somewhere with the numbers.
