wat does it meAns??(end fitting ms per 33656-12)
What do you mean?
MS 33656-12
MilSpec yada,yada...it's a standard established by the U.S. military regarding different kind of connectors, so that the suppliers all produce to the same standard. Ensures that everything fits the way it's supposed to.
actually i want to know about this standrad detail.can any one give me the knowledge of those standrads details.wat does it meAns??(end fitting ms per 33656-12)
thanks svenakela for information about fittings but still looking more detail in shape of drawings or 3d models .
is'nt it just AN -12 37* flared end fitting? What do you need it for?
I think i am not understading u guys actcally i have a drawing for manufacturing the componant .dawing giving me all the information about part except this portion(please see the attachment for portion i cant show u complete drawing because of some confidentiality sorry to say ).on that portion there is note a written ,says ??(end fitting ms per 33656-12)
MS 33656-12 refers to a flared fitting for 3/4" tubing
The specification was cancelled on 18 October 1993 and replaced by AS4395 (SAE spec)
You will need to buy the specification to get those dimensions
Aaron
This portion describes the thread only. From what I can find, MS is a military standard and the same spec as 1.0625-12 UNJF-3A. The remainder of the fitting profile may be described elsewhere on the print.
UNJF threads have an inspected radius profile in the root of the thread along with a larger minor diameter for greater tensile strength.
DC
you can go and ask on
www.eng-tips.com
thanks for the co operation of all the great peoples
thanks
asif
