586,060 active members*
4,090 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > VMC Mill Splash Guard design 2nd Iteration
Results 1 to 6 of 6
    Oct 2010
    1189
    Hi i want to share my new achievement with you ,..
    I do have an Klippfeld F12A which i Factory Retrofitted CNC using Linuxcnc and i am Happy but ,..
    Looks like Attachment 243656 (has similar Travel like Tormach 1100 )
    Milling is only possible in Bath gear - (the factory guards are nice !)
    So my first iteration looks like
    Attachment 243654
    Which did work to some extend but after some research i wanted more (beside ATC Spindle but that is another story) so i made several designs
    I want an stabile Bridgeport (i retrofit an 412 right now) like design no fancy style a tray for the chips simply
    So i printed tha rough size of the mill in 3d printer (in small of course)
    Attachment 243658
    and tried several way how to best have all covered up.
    Not so good Attachment 243660
    final approach
    Attachment 243662
    So it is detachable if needed and on the back side there is plenty of space for all electronics (like in the Bridgeport 412) for pc , VFD, controllers and so on.
    I only transport an USB, 12V for the screen and an LPT Cable for the keyboard to the front side where i have all i need (here the bridgeport Panel Attachment 243664
    So first we started with the Base Plate (where i have to lift my Mill head away to exchange it )
    Attachment 243666
    (Remark : The Mill-machine is build in that factory so they used an unfinished machine to test for the fit ,.. -
    You can see the standard stand (small they also have an wider one ) where i inter to put the Pump and Tank then i still have space for store the tools if needed
    I designed chip traps underneath the machine
    Attachment 243668
    Then the fittings for the left side of front panel
    Attachment 243670
    The back wall is made of 1,5mm sheet metal which is detachable therefore we need some rails
    Attachment 243672
    This is how the front side looked in an early stage
    Attachment 243674
    And here tha back side
    which takes 2 standard rails
    safety switch ,
    VFD controller and PC
    Attachment 243676
    final the front side has an top and bottom bar where the screen and keyboard is attached (similar to a haas)
    this weekend i will assemble all then there should be new fotos
    i also bought the plastic covers for doors and left and right gards they have to be cut and bended Finnish ,..
    more to follow
    Aug 2006
    1602
    Re: VMC Mill Splash Guard design 2nd Iteration
    Very nice looking enclosure! Are the sides just sheet metal, or have you got some stiffening to stop it vibrating when the mill is running?
    Oct 2010
    1189
    If you mean left and right they have stiffing Inside and the right one also has to Curry the top part of the arm where Screen and Buttons are. So i expect not so much Vibration but we will See it is an Kind of prototype ..
    Oct 2010
    1189
    The weekend has come and we where somehow successful
    Before picture
    Attachment 245272
    The green cable is an split water hose to protect the machine by lifting.
    then we build some rigg for lifting.
    Attachment 245274
    Unfortunately the motor i bought was not able to lift the weight (even if the spec said so ,.. but that is another story )
    but plan b we where successful
    Attachment 245276
    As you can see we had to remove the x y axis but it is also a chance to redo all the wiring to be oil safe.
    so the next stepps will take some time
    Aug 2006
    1602
    Looking good! Does that mill have linear rails on all the axes, or just the Y?
    Oct 2010
    1189
    Hi it has linear rails on all 3 axis i have to rework the x axis Motor cabeling ,.. But this week i should Finnisch my atc Part of retrofitting an bridgeport 412 ,...
  1. Splash Guard
    By AVRnj in forum Tormach Personal CNC Mill
    Last Post: 04-16-2014, 03:05 PM
  2. New, improved splash guard
    By tbaker2500 in forum Tormach Personal CNC Mill
    Last Post: 02-09-2013, 05:48 PM
  3. New splash guard
    Last Post: 03-17-2012, 02:01 AM
  4. Splash Guard for 8x12 Lathe
    By caleb105 in forum Mini Lathe
    Last Post: 11-13-2009, 11:17 PM
  5. Splash Guard for HF 8x12
    By jk080 in forum Mini Lathe
    Last Post: 01-13-2008, 02:01 AM
