Attachment 258536Attachment 258538Attachment 258540
Vision LED 2.0 Ring for Knee Mills
Designed to fit Bridgeport Knee Mills and clones.
Attaches to face of quill, 3 options available.
Uniform lighting, no heat, no shadows, lifetime warranty!!!
All the info you need is in the ebay listings below....
Ebay item numbers are as follows:
400741078937 - Dimmer Switch
400759473641 - Straight Plug
400759477100 - On/Off Switch
10% discount for CNCZONE members.
I also have a Vision 5.5 LED Ring.
Ring has 5.5" bore and is ideal for machines with CAT50 toolholders.
198 LEDS, 7.625" O.D. and 5/8" thick, thin enough where it will not
interfere with most atc. Everything is 100% completely waterproof.
I also make custom sizes, any shape to fit any machine.
Contact me anytime via call or text - 1-704-472-9530
