587,180 active members*
4,269 visitors online*
    Jan 2006
    204
    Viper 250 ??????
    are viper 250's available and what is the cost
    Thank you
    archie =)=) =)
    Feb 2007
    966
    No, sorry not right now. I'm finding the IR2104 driver isn't a good match for IGBT' since you can't program an off time.
    I should have a new board for 3PH and brushed DC by the fall, that will use a different driver and run a full 350 volts.
    Jan 2006
    204
    viper 250
    I guess it will have to be the 200 as i am going to run this on single phase 220 I probably don't need anything bigger anyway.
    archie =) =) =)
    Bridgeport R2E4 retrofit in progress
  1. New: Baby Viper 60
    By Larken in forum Viper Servo drives
    Last Post: 11-21-2012, 01:53 AM
  2. SD-1525 vs Viper?
    By erikjgreen in forum Vertical Mill, Lathe Project Log
    Last Post: 09-20-2011, 03:07 PM
  3. Viper 950 VMC - Communications
    By grttt3 in forum Uncategorised MetalWorking Machines
    Last Post: 03-11-2011, 10:29 PM
  4. new for: viper v-500/mitsubishi VLC
    By fenix728 in forum MetalWork Discussion
    Last Post: 11-26-2008, 08:48 PM
