587,499 active members*
4,592 visitors online*
    Aug 2014
    103
    vfd speeds for gear driven box
    what speeds are people running there rf-45 ect with, using vfd ans standard gearbox. @50hz in top gear its 1600 rpm. @ 400hz that equates to 12,800. im programing the vfd now awaiting the drive and was interested to see what others are getting.
    Aug 2013
    194
    Re: vfd speeds for gear driven box
    Is your motor even capable of 400hz?
    I run mine @ 60hz since that is the max freq listed on the motor specs. This particular motor at that freq runs around 4,200 RPM when in top gear. I generally just rely on the gear changes for lower speeds and only lower the freq when I am in the lowest gear for things like coaxial indicators.
    Aug 2014
    103
    Thanks Draczny for the input, I stuck with the 4 pole motor, as @ 50-60 hz its rated at 1.5kw, @ speed's above that torque drops off, and anything above the 1600rpm, is mostly fine cutting, I thought that was better suited for my applications. for any1 wondering @100hz it runs at 3200 rpm at the spindle in high-high and that's as much as i would ever like to run the gearbox, even at that the oil starts to froth up slightly. The motor is running @ 2 pole speed. an as for the 400hz the vfd is capable, but the motor definitely not.
  1. Bevel Gear Cutting with Involute Spur Gear cutter
    By basalt in forum MetalWork Discussion
    Last Post: 05-06-2012, 10:13 PM
  2. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  3. belt or gear driven?
    By mikeph in forum Bridgeport / Hardinge Mills
    Last Post: 11-24-2011, 07:18 AM
  4. What size gear belts for stepper gear reducer?
    By Danno in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-28-2011, 10:28 PM
  5. direct driven or belt driven
    By jeremy0203 in forum Benchtop Machines
    Last Post: 07-27-2011, 05:23 AM
