587,419 active members*
3,276 visitors online*
Results 1 to 2 of 2
    Aug 2007
    22
    vfd on shopmaster bridge mill
    I have considered putting vfds on my shopmaster bridgemill instead of using the step pulleys that came with the machine. what I have learned from the vfd supplier is that the motors are constant torque up to the base speed of 1800 rpm. If I use the step pulleys at 200 rpm I will have 9 times the torque at the spindle than the vfd will provide at 200 rpm out. Is there a solution for the torque decrease problem maintaining the same size hp motor other than taking a much lighter cut.
    Brucesu1
    Apr 2006
    24
    Smile
    You should keep the step pulleys. If you install a VFD, you will not have to change pulleys very often but will still want the capability to do so.
  1. Need to buy a shopmaster for ductwork
    By dlemay in forum Bending, Forging, Extrusion...
    Last Post: 04-03-2007, 05:51 PM
  2. Carl's Bridge Mill/Router
    By DDM in forum CNC Wood Router Project Log
    Last Post: 12-31-2006, 06:30 AM
  3. Discussion: Using aluminum tooling plate to build a bridge mill.
    By Deviant in forum Uncategorised MetalWorking Machines
    Last Post: 08-11-2006, 07:18 PM
  4. running a bridge knee mill
    By MBG in forum Bridgeport / Hardinge Mills
    Last Post: 06-12-2005, 03:44 PM
  5. What motors with shopmaster
    By mysterious in forum CNC Machine Related Electronics
    Last Post: 02-23-2004, 10:10 PM
