Hello guys,
I have a Huanyang VFD 100v-110v and I need help for parameter settings.
I need to set it to be controlled by USB CNC controller board and connect to spindle.
The spindle is:
GDZ-15, Diameter 65mm, H160mm, 400Hz, 24000 rpm, 800w, 6A, 150V.
VFD MODEL: HY01D511B, 110V-110V, 1.5KW, 14A
I tried these settings before:
P0=0
P1=1
P2=1
P3=400
P4=400
P5=400
P8=150
P70=0
P72=400
P73=0
P141=150
P142=6A
P144=24000
P142=6
After putting these parameters, I don't know how to activate them because the VFD screen remain blinking (see picture)
After these parameters, I got others which are a bit similar to the first ones but the VFD screen remain blinking an on the picture:
PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
PD001=0 (1 For Remote Control)
PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
PD003=400
PD004=400
PD005=400
PD007=20
PD008=220 (120 If you have 120v VFD )
PD009=15
PD010=8
PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
PD014 Acceleration=12 ( Adjust to suit)
PD015 Deceleration=12 (Adjust to suit)
( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
PD141=220 ( Motor Rated Voltage ) (120 for VFD Rated for 120v )
PD142= ( Motor Max Amps)
PD142=( 220vSet for your motor Amp Rating 2.2Kw Spindle 9 amp )
PD142=( 220VSet for your motor Amp Rating 1.5Kw Spindle 7 amp )
PD142=( 220v Set for your motor Amps Rating 800w Spindle 4 amps )
PD142=( 120v Set for your motor Amp Rating 800w Spindle 7 amp )
PD143=2 ( Motor Number of Poles)
PD144=3000 (Max Motor RPM) =3,000= (24,000)
PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
PD72=400
PD73=120 ( 100 Minimum Setting )
So, I realy need help to set up this VFD.
Thank you in advance
