I was doing a job yesterday and was doing some simple 3/8 16 tapped holes. As the tap was reversing it broke coming out. I pulled out the tool and replaced it. As I was replacing the tool (machine not running) the control alarmed out. I am now getting a "Control Overheat 122" message. I come up about 4 minutes after the machine is turned on even if I do nothing. Is this a sensor failure? Not even sure where to look. I believe this is a 1995 VF2 7500RPM 10HP.
