587,920 active members*
3,476 visitors online*
Results 1 to 7 of 7
    Apr 2005
    713
    VF-2: Will Kurt D688 fit?
    Hey guys, I'm buying a VF-2SS and need to buy my vices, but can't get a straight answer out of my dealer about whether or now Kurt's longer 6" vice (D688) will fit on the table without running into the sheetmetal. I'd prefer to bolt the vice down to the center T-slot.
    Jul 2005
    12177
    Quote Originally Posted by Matt@RFR View Post
    You will have no problem. The vise can hang out almost one inch behind the table and still be clear of the way covers. Mounted to the center tee slot the D688 is back about an inch from the edge of the table. You can easily mount the Kurt 6" Duolock vise on the VF2.
    And if you are running multiple parts think hard about getting the Duolock; it is about twice the price but you can recover that in a short time when doing twice as many parts per cycle.
    Apr 2005
    713
    Thanks Geof. I was more concerned with the overhang off the front of the table, which by my math, is about 4 1/8" plus the spud for the vice handle.
    I'm going to atleast start out with two D688's because some of the work I've been looking at is bigger flat bar parts (1"x8"x28" for example) that I'll need to hold over two vices, but I appreciate the advice and will look into it once this machine is on its feet.
    Jul 2005
    12177
    Thanks Geof. I was more concerned with the overhang off the front of the table, which by my math, is about 4 1/8" plus the spud for the vice handle......
    At the front the hex drive end comes up about one inch shy of the edge of the drip tray on the table.
    You need to extend the vise handle unless you enjoy smashed knuckles.
    Aug 2003
    812
    I took off that drip table, got tired of not being able to use the long handles.
    Kurt 688s fit fine you can get three on there easy.
    Apr 2005
    713
    Perfect, thanks a bunch guys. The machine should be leaving the factory in three days!
    Jul 2005
    12177
    Quote Originally Posted by nervis1 View Post
    I did the alternate and extended the shaft on the vise handle to reach out the door. This has the added advantage that the door cannot be closed with the handle still on the vise.
  1. Kurt DL600 Double Vise
    By Fudd in forum Uncategorised MetalWorking Machines
    Last Post: 08-06-2010, 06:41 PM
  2. kurt vise quality?
    By jed102 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-13-2010, 05:05 AM
  3. Which Kurt Power drawbar?
    By acerocket in forum Bridgeport / Hardinge Mills
    Last Post: 09-14-2006, 05:02 PM
  4. Kurt drawbars
    By MrWild in forum Bridgeport / Hardinge Mills
    Last Post: 07-27-2006, 02:58 AM
  5. Which Kurt Vise to get for CNC
    By JMFabrications in forum Work Fixtures / Hold-Down Solutions
    Last Post: 03-27-2006, 06:07 PM
