587,180 active members*
4,293 visitors online*
    Mar 2011
    0
    versa laser vl200 engraving table needed
    Greetings,
    I purchased a used vl200 25 watt. It didnt come with an engraving table. I realized that in order to zero the machine correctly it wants teh engraving table. Does anyone have one to sell.
    Or i was thinking of making my own but its not as simple as putting a sheet of aluminum down. I need the epecs of an existing one. How thick is the piece? If i dont have that compensated for the laser will be off the difference of how thick mine is compared to how thick the real one is supposed to be. What two pins are jumpered together? by knowing this i can make my own jumper so that the laser knows i have the engraving table plugged in.
    Jul 2008
    776
    What do you mean - do not have engraving table? Does it means that you have inside only Z motor and table supports?
    Mar 2011
    0
    I have the honeycomb table, but that has a different pin setting, so therefore it doesnt zero correctly. In order to calibrate teh machine correctly ULS informed me i need the engraving table plugged in.
    This is generating the problem that the table wont rise close enough for the laser to be within 2 inches of my project.
    even though when i calibrate it I save the Z axis when it is zeroed in with the table 2 inches from the lens.
  1. Laser table wont lift up (GCC/ Laser Pro Mercury II)
    By aussiemate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-30-2014, 01:34 PM
  2. versa laser, laser engraving
    By cadmaniac in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-25-2010, 08:30 PM
  3. Laser Engraving help needed
    By viroy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-22-2008, 07:29 PM
  4. Needed: laser engraving job shop in Florida
    By jimc in forum Engraving Machines
    Last Post: 12-07-2007, 08:05 PM
  5. ULS vl200, m-300
    By [email protected] in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-22-2007, 09:21 PM
