I am just starting off and was wondering if someone could explain to me the difference between velocity and acceleration. Also, what is the relationship between the two?
Stefon
Stefon
Acceleration is how fast it moves up to speed, Velocity is the speed it moves at.
The precise definitions which you would have learnt in Physics at High School or College is that Velocity is the Speed at which something is moving in a specified Direction. And of course Speed is distance moved per unit of time; feet per minute, miles per hour, meters per second, etc.
Acceleration is the rate of change of speed per unit of time. For instance the acceleration of a free falling body near the surface of the earth is very close to 32 feet per second per second downwards. When you release an object it is travelling at a speed of 32 feet per second after one second and 64 feet per second after two seconds and so on when air resistance is ignored. Actually for a falling body because it is going in a specified direction it is correct to say that its Velocity increase; Velocity is always the combination of Speed and Direction.
And to add the other maxim, a body at rest tends to stay at rest, a body in motion tends to stay in motion.
IOW, simplified, the effort is usually in getting a body up to the final velocity (acceleration) and effort to return to zero, (deceleration).
In the CNC context, the inertia of the load has a very important effect on motor sizing, and is dependent on the acceptable or desired accel/decel.
Al.
Albert E.
