Tom,
Thanks for putting up with my nagging questions. Lol. I have some interesting ones:
1. How do you assign a value to a variable in a c. program then once the KFLOP has powered down, hold those values. Once I power back up, read those values back into the variables to which they came.
2. Is there a way to use tapping in Mach3 without having to supply the parameters first?
3. If I am running Mach, is it better to use Mach to provide logic to run the ATC or have KFLOP do all the work and report back when done using MachNotify?
4. Probe inputs - I will be setting up with both a touch probe and a tool setter. Which inputs are best and why? Are there high speed inputs?
5. How many Kanalogs and Konnect boards are we limited to in a single KFLOP system?
I think that is it for now. Thanks again.
Regards Sir
