587,832 active members*
3,429 visitors online*
Thread: Vacuum table
Results 1 to 5 of 5
    Mar 2010
    115
    Vacuum table
    I was just thinking (yeah, generally bad idea...) about doing a vac table setup.
    I'll probably go MDF, so when it inevitably gets cut up, it's cheap quick and easy to replace. I was going to go with the simple design of squares across the whole surface, with (.25" * .25" ?) channels between.
    Since my table isn't the same size as everyone else's, and no doubt many people are doing the same thing... Would it be hard for someone to come up with a little gcode generator where you could just plug in your X&Y sizes, and have it spit out a table in essence? Maybe let you specify the rim/lip/edge size?
    Thoughts?
    Mar 2010
    6
    Quote Originally Posted by Dr.Fiero View Post
    Thoughts?
    it is very easy to do. with a few lines of code you could prepare the gcode for a table. just use subroutines. we always prepare the tables like this.
    Mar 2010
    115
    Yup... Could just do it by hand for myself.
    I just thought it might be nice for everyone, if someone could whip up some code.
    Mar 2010
    115
    Soooooo.....
    Anyone? Anyone? Bueller?
    Jul 2013
    14
    If you go with MDF you will have problems, mdf is pours, start with a sheet of cellular pvc non pours. What type of router do you have? what programs are you running your router with?
  1. Vacuum table
    By Maderhobby in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-22-2012, 11:46 PM
  2. Vacuum table
    By RCjunkie in forum DIY CNC Router Table Machines
    Last Post: 06-21-2012, 08:49 PM
  3. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  4. Vacuum Table where to next.
    By Steveb1307 in forum DIY CNC Router Table Machines
    Last Post: 11-29-2011, 04:56 PM
  5. Vacuum table
    By balsaman in forum DIY CNC Router Table Machines
    Last Post: 01-05-2004, 03:18 PM
