Does anyone know if and how to get the tool label to post in a program. I am looking for in in the head of the program.
Thanks,
Fred
Thanks,
Fred
w
Do you output "DIAM_OFFSET" as text like that?
I see spaces, but that could be the forum doing that. Can you paste your 110 line in code blocks (The hash/pound sign at the format bar)
SBC is right, just put it where you want the Tool Name and info to appear.
It won`t call the tool label up correctly in the tool list, I usually have it appearing at the start of the feature right after the feature name.
So it would output something like:-
(JOB 1 POCKET)
(8mm Carbide Ball Nose 3 Flute)
If this is something like what you`re after then try putting the tool_label into lines 2,3 and 4 immediately after the feature comment, eg :-
feature_name_comment
tool_label
Regards
