587,104 active members*
4,270 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V24-Break Entity command is deleting segments and UNDO won't bring them back
Results 1 to 2 of 2
    Mar 2006
    168
    I've noticed this a few times. I've sort of overlooked it and just re-drew in the geometry but it's starting to cost some time now (loosing things that have had lots of editing done on them). Is there a way to fix this? I never noticed this happening in V23.
    May 2008
    244
    there is one thing i can say is that my undo button has always worked in v24,
    if the arrow could be worn off it would be gone
    possible something did not install correctly
    may need to let bc sort through your install
    something to remember in v 24 you have quick trim
  1. trying to bring L-Tec piecemaker back to life
    By lookinfor in forum Gecko Drives
    Last Post: 01-19-2012, 12:39 AM
  2. Undo limitations
    By Species8472 in forum Solidworks
    Last Post: 08-29-2011, 04:08 PM
  3. Undo work not correctly in BCC V24
    By Questionguy in forum BobCad-Cam
    Last Post: 02-13-2011, 04:12 AM
  4. Why surfcam doesn't have UNDO feature?
    By qmas99 in forum Surfcam
    Last Post: 04-17-2007, 02:45 AM
  5. Really, only one undo!
    By MikeA in forum Mastercam
    Last Post: 09-27-2003, 03:23 PM
