587,786 active members*
2,174 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V23 Need help with a gear (spline)
Results 1 to 20 of 20
    Jan 2013
    25
    Hey guys, first post. I am new to bobcad, had it for a while but am not very savy with drawing. I have a spline that I cant seem to figure out how to draw. The closest thing that bobcad has for a template is a gear. I have attached a picture of what I am trying to do. Any help would be appreciated.
    Dec 2008
    4548
    Did you get an answer yet? Create a triangle from the walls of one of the teeth. Then rotate/copy 4, 360. Then rotate copy those 45 degrees. Then rotate copy those 22.5. Break all of those and clear out the middle. Extrude the "star". Create a circle at the inner diameter of the tooth and extrude that and boolean union it to the extruded star. Create a circle at the outer diameter of the tooth and create another one well outside of the part. Extrude those 2 deep enough to encase the part and boolean diff that from the part.
    Jan 2013
    25
    I appreciate the reply because no one has but what you said may as well be in Chinese. Haha! Ill give it a try though. I actually dont need those two circles shown, I just need to know how to draw the spline and edit it occasionaly for different parts.
    Apr 2009
    3376
    Quote Originally Posted by jaredg View Post
    I started a thread to find out what happened to
    http://cadcamtrainer.com/forums/forumdisplay.php?f=2
    I was thinking the tutorials Sorin had there are excellent for a beginner and one in particular"Wagon Wheel"would pretty much get you on your way,and you understand and learn alot,instead of just telling you how to do it.BUT the "Injuts"or whatever they are called ruined his site.Burr set you the steps out,use HELP,and ask more questions if you get stuck.
    Jan 2013
    25
    What I have done so far is create circles to the outside of the teeth and inside of the teeth. I am stuck because I dont understand what to do next.
    Mar 2007
    207
    Just keep an eye at the bottom left when doing such operations... It tells you what to do next. And remember when rotating... if you want 6 then copy # is 5... you already have one. What Burrman said is or seems alot... it's not in reality ... Just one step at a time.... Good luck
    Using CNC Masters Supra Knee Mill, 4 Axis vari speed. Bob Cad V-23, V26, Bob Art
    Mar 2007
    207
    Think you need to make the teeth.... Practice the rotate... make a new file and put a circle at say x 2" Then rotate it. If you want 6... you can do the math in the edit box... just type 360/6 and press enter. make 5 copies.... select the circle you made when prompted... and bam... play with that then try and tackle Burr's stuff.....
    Jan 2013
    25
    Why would I want to rotate a circle?
    Mar 2007
    207
    To practice using the feature.... hypothetically it could be a drill hole... you make one and rotate... BC makes the rest.... What Burr told you is pretty complicated.... If you don't know how to use the feature... it will be that much worse
    Apr 2009
    3376
    Burr is an ALL STAR movie maker.Do I git the popcorn a popping?
    :banana::banana::banana:
    I a crummy movie mogul.There are many ways to approach this.I have a hunch someone is going to show you shortly.I don't want to step in and confuse on how I would do it..Albeit Burr's way is probably better.A movie would way better show and help you understand,however I can show you,it will just take a bunch of pics to explain.I realize you are a beginner and I can relate to that Foreign language thing.
    Jan 2013
    25
    If I managed to make one of these shapes would I be able to easily edit the OD and ID of the teeth as well as their widths? Or would I start fresh every time? I make dies for bolts and nuts and these dimensions change regularly.
    Apr 2009
    3376
    I have a question,are you doing this just for drawing purposes?If not is this a 4th axis indexing or EDM?
    Dec 2008
    4548
    Here's a short example...
    http://youtu.be/uranzGUFNQo
    Well, if the angles were always the same, you could save a template of the "star", then just recut/boolean with the 2 radius's for a new gear.
    Jan 2013
    25
    THis is for an actual job. That is a customers print. I am using this to create a wire EDM program for my HS70. Usually we just buy them on the outside and Id like to start making them.
    Apr 2009
    3376
    You need 2D then.We can't see all the information given.Caution on one thing is I do not see anything indicating that the top and bottom of spline is arcs,looks to be lines.
    Dec 2008
    4548
    Ok:
    你得到答案了嗎?創建的一個齒的壁從一個三角形。然後旋轉,360/複印4。然後複製這些45度旋轉。然後旋轉複製這些22.5。打破所有的人,並明確了中間。擠出的“明 星”。創建一個圓在牙齒的內徑和擠出和布爾工會它的擠出星級。創建一個圓的齒的外直徑,並創建另一個阱 的部分之外。擠出足夠深包住的部分和布爾值的差異,從部分
    Mar 2007
    207
    I see that even in Chinese on line N72 it still throws in that G17..... Just saying...
    Jan 2013
    25
    My gratitude for the YouTube video!
    Mar 2007
    207
    Damn Burr that was a hell of a nice video.... You ever concider doing more of them.... A little bit of talking wouldn't hurt..... you went a long pretty damn fast... obviously very skilled at working the program, but as fast as you went.... you would be great at doing some instructionals.... Hell I would have to pause to get the numbers off a scratch pad longer than the whole video you did....LOL great job Man...
    Dec 2008
    4548
    Quote Originally Posted by Martin 007 View Post
    Lol............ :stickpoke:
    I have heard this before. Maybe I should just talk no matter what.. I didnt want to just talk to hear myself. I usually save that for something I think needs explaining.
    Just a simple command overview is kindof self explanatory?
    Anyway............
  1. Gear or Spline
    By eyesociety in forum EUROPE RFQ's
    Last Post: 11-18-2013, 07:49 PM
  2. Bevel Gear Cutting with Involute Spur Gear cutter
    By basalt in forum MetalWork Discussion
    Last Post: 05-06-2012, 10:13 PM
  3. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  4. Single Point Gear Spline Broaching?
    By Jake@SRM in forum Haas Mills
    Last Post: 02-13-2012, 12:26 PM
  5. Need a Lagun Lathe Gear or Custom Gear Maker
    By douglasco in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2011, 03:54 PM
