587,517 active members*
3,471 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V21 solidworks to toolpath problem
Results 1 to 4 of 4
    Sep 2006
    39
    I am having trouble with a poor finish when I generate a tool path from a solid works model. I can send the solid works model to anyone who can help.
    settings are:
    planer tool path
    0.25 tool dia
    ball
    using tool tip
    .007 step over
    tool angle 0
    tolerance 0.0003
    min line length 0.0003
    tightening the tolerance and line length has helped but I am still not happy with the finish. If you back plot the file and look at the area around X-3.1234 Y-0.149 you will see the problems. I hope I uploaded the file properly, thank you everyone
    Attached Files Attached Files
    Mar 2005
    368
    Keep tightening up on the Tolerance setting.
    I remember using .0001" or even .00005" to address this very problem.
    It's going to bloat the code....
    No need to mess with Min. Line Length.
    Sep 2006
    39
    Thank you
    Are you talking about the tolerance on the cad side? Or the cam side? Or in the optional fields that you fill in as you are creating the tool path?
    Mar 2005
    368
    Quote Originally Posted by lostpinky View Post
    ....fields that you fill in as you are creating the tool path?
    Yes, here ^^^^
  1. Toolpath problem
    By sweetwood in forum Mastercam
    Last Post: 07-14-2010, 06:35 PM
  2. toolpath problem
    By Nicovm in forum Jewelry Design Software
    Last Post: 09-02-2008, 07:39 PM
  3. Toolpath Transform problem...
    By kprice1658 in forum Mastercam
    Last Post: 03-13-2008, 07:07 PM
  4. Help toolpath problem
    By cam168 in forum Mastercam
    Last Post: 01-18-2008, 02:03 AM
  5. V9 Toolpath Problem
    By Clawsie Machine in forum Mastercam
    Last Post: 12-01-2007, 08:34 AM
