Just took delivery of my used 2000 ML15 and noticed the drive belts are pretty shredded . These are the VEE belts from the drive motor to the head gearbox .
The manual does not tell the part # . It just says "belt "
I know this is an imported lathe bed , so it's probably a metric belt .
The only numbers on the belt are : 1783
It measures approx 75" in length and is about .540" wide .
Where do I get these belts ? I need 3 of them .
This probably explains why the PO needed a bigger machine with more power .
It was only running 2 of 3 belts and one of those had flat spots !
