587,406 active members*
3,254 visitors online*
Results 1 to 2 of 2
    Nov 2004
    69
    UV Flatbed printers
    Hopefully somebody out there has some knowledge of these.
    I want to print designs using various translucent colors on clear acrylic. The remainder of the area will be non-translucent Black. The area behind the design will then be backlit allowing the non-Black areas to "lightup".
    Are UV Printers a good choice for doing this?
    Larry
    Nov 2014
    8
    Re: UV Flatbed printers
    No. All uv ink is somewhat translucent. The black you would have to use black vinyl.
  1. Hoss's 3D Printers
    By hoss2006 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-27-2015, 04:05 PM
  2. 3D Printers why so quite on here?
    By xairflyer in forum 3D Printer / 3D Scanner Discussion
    Last Post: 07-17-2012, 04:55 AM
  3. 3D printers and CNC Routers
    By jeb92 in forum Hobby Discussion
    Last Post: 11-11-2010, 02:03 AM
  4. surplus printers ????
    By turmite in forum DIY CNC Router Table Machines
    Last Post: 07-03-2009, 12:14 AM
