Originally Posted by
trialanderror
I was wondering if its a common practice to use premade casted blanks for high production machining operations.......Is there any quality difference?
Aluminum casting alloys have a different composition to extruded alloys. They generally have a lower ductility and a higher silicon content and need a two stage heat treating process to give them maximum strength and machinability.
The higher silicon content means they are more abrasive so tooling does not last as long and the lower ductility can result in less strength in tapped threads.
Casting a part just slightly oversize and then fully machining it is not likely to save money. The combined cost of pattern/mould making, casting and heat treatment along with the reduced machinability, would probably be more than the cost saving on the reduced metal removal.
If a part has a complex shape that can be created by casting so that very little machining is required, in other words just the surface of mating parts or spot facing for bolts, then it may be more economical to cast rather than machine from solid. However, the cost of making patterns/moulds has to be considered so casting is not practical for small numbers of parts, small being less than a few thousand up to tens of thousands depending on the complexity of the art.
