587,731 active members*
2,708 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > Usb SS + G540, charge pump question?
Results 1 to 2 of 2
    Sep 2007
    200
    I am in the middle of a rewiring of my control cabinet with the usb smooth stepper i purchased a while back and have hit the wall trying to tune the motors.
    I have read that the smooth stepper may not require the charge pump feature on the g540. and also that the g540 has a switch for turning off the charge pump.
    i have tried the setup with and without the charge pump however neither setup got any response at the motors (the g540's status light, lights up only if the charge pump is disengaged).
    the smooth stepper drivers seem functional (i get consistent status lights from the board) and the mach3 profile i am using is just like the G540.xml
    It seems i just need a few notes on how to setup the charge pump. Do i need one? could i still use it?
    if anyone has some info it would be appreciated.
    Sep 2007
    200
    I just had a another go at setting up with the charge pump engaged. no result.
    I have the charge pump set to: port1, pin16, active high,
    in the general configuration i have set: charge pump on in e-stop.
    i have tried two different cables
    and when i refresh mach3 i get the message: external e-stop requested
    if anyone knows what i have missed please, give us a shout!
  1. G540 charge pump fault, no motion. Settings?
    By JosephD in forum Gecko Drives
    Last Post: 01-29-2013, 03:12 PM
  2. G540 charge pump & Mesa 5i20
    By cartula in forum Gecko Drives
    Last Post: 04-29-2011, 05:05 AM
  3. G540/Mach3 charge pump fault LED is lit
    By will gilmore in forum Gecko Drives
    Last Post: 04-13-2010, 02:26 AM
  4. G540 charge-pump not pumping
    By aystarik in forum Gecko Drives
    Last Post: 05-14-2009, 08:38 PM
  5. G540 Tempremental charge pump detector
    By David Campbell in forum Gecko Drives
    Last Post: 03-20-2009, 01:18 PM
