Hi guy's !
We are in process of upgrading our programming software but have a hard time finding what suits us.
We are currently using completely unlocked CMS Wintools as the main programming software. What's annoying is that the program is getting pretty old so we cant run higher than win98. As you guy's know it's time to change when you need other computer posts just to scan your drawings cause your new scanner isn't compatible with win98.
Now to let you guy's in on how we operate.
We program with the actual language of CMSwintools no g-codes no CAD options. This means that we program and apply tool path's before and without even touching the "create line" in the cad/cam software. Basically we create the .txt file that the software creates when you acualy draw and add your tool path to that first line.
This way of parametric programming lets us use only one model program to machine the interior of any different width length and height of a part. Making one program for all is letting us work with a system that is almost 100% automated.
Another point in this is that we only have to scan the order's bar code and the system automatically pickup's up the width length height and model and the amout of parts of the order.Then the generator's job is to simply place his tools in the rite spots for wintools to read our .txt file (model program) and generate it to send to the cnc.
Now i know some of you will say that wintools can be compatible with higher than win98. But not by the way we use it. Believe me we checked.
We looked it out with MasterCam and SolidWorks software programmers at a CNC show but didn't seem to be able to completely suite us.
And then i heard a bit about AlphaCam that seem to maybe have what we are looking for.
So who and whats next ?
I appreciate any new help and info on if there's a software for us.
Pat.
