587,754 active members*
3,007 visitors online*
    Jun 2014
    777
    Unwanted vibration
    Hi there.
    I'm currently cutting out 120mm circles in 25mm ply and ive started getting vibration which starts at around 3/4 of the way around the circle and end when circle is complete. 7mm doc, 6mm up cut compression spiral. Any ideas? Could this be incorrect backlash comp? No signs of backlash in the cut itself.
    35538
    Re: Unwanted vibration
    Vibration in the plywood, or the tool?
    If the cutout portion of the plywood is not held in place, it may vibrate a lot.
    Never used backlash comp, and wouldn't recommend it. If the tool has to stop and make corrections, it could easily grab the plywood and cause vibrations.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2013
    480
    routers often have stiffnesses that are not symmetrical in every direction, and change with the Z axis height and location of the X and Y axis.
  1. unwanted G1 command
    By homerswitch in forum Uncategorised CAM Discussion
    Last Post: 03-23-2011, 02:51 PM
  2. unwanted item
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 07-17-2010, 03:09 PM
  3. unwanted g43 in nc file
    By sgault in forum Mastercam
    Last Post: 04-21-2010, 04:06 AM
  4. unwanted features
    By caddisfly in forum BobCad-Cam
    Last Post: 07-20-2009, 06:12 PM
  5. Unwanted Z-movement...
    By sweFredrik in forum Machines running Mach Software
    Last Post: 04-27-2008, 11:40 PM
