587,345 active members*
3,506 visitors online*
Results 1 to 5 of 5
    Jul 2006
    6
    unwanted circles along curve
    In my drawing I have a curve, when I simulate the g code I get small unwanted circles along the curve. Im new to this , any suggestions?
    Thanks,
    Paul
    Aug 2005
    157
    What software are you using? I had a similar problem using g-code generated using a Mach 3 demo and trying the same code in EMC (AXIS). One used I-J absolute and one used I-J relative (I don't remember which was which)
    Jul 2006
    6
    I am using bobcad and turbocnc. I managed to get the circles out of the simulation in bobcad by changing various g code settings but the circles should up in turbocnc.
    Paul
    Jan 2006
    4396
    Funky Wackedout Circles on Arc Profiles
    In BCC you will have to open the CAM side of the software and select a post processor. Go to Setup>Driver>General and select the way your machine controller uses arcs. Save these setting for that post processor and regenerate your tool path. This will fix that problem.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2006
    6
    thanks for the info, I will try to find one that works with turboCNC
