587,507 active members*
2,722 visitors online*
Results 1 to 14 of 14
    Jul 2005
    29
    Uneven finish
    Hello, I am having a problem when cutting a dome or 3d relief. It is adding small lines or ripples (not stepover) perpendicular to the cut direction eg: if rastering in X the lines appear in the Y direction and vise versa, they also appear in offset cut as well.
    I have tried differnet computers, different versions of Mach3 and Smooth Stepper plug ins & drivers (last two). Also gcode from Artcam and Aspire in three different output types.
    The only conclusion I can come up with is the Smooth Stepper as this hadn"t happened using the printer port. Please let me know if you need anymore info or would like the XML & Gcode files for review.
    It's not vibration or chattering, also ran code first at 180ipm then at 120,100,80,60,30ipm all with the same result. It does appear more pronounced the larger the job size. I was testing using an 18 degree dome 4"Y 6"X about .125 high with a .125 ballnose with 6% steppover. Also Tried enabling and disabling CV settings all with the same result.
    Thanks Robert
    (Not sure if this is in the correct place, Moderator feel free to move)
    Jul 2005
    29
    Nobody has ANY ideas or recomendations?
    Warp9 recommended reversing the polarity for the step signal, but that didn't help. I have attached a crude and exaggerated drawing.... The "bumps or lines" are only about .003"
    Mar 2006
    489
    Can you physically see the z axis move up where the lines are appearing?
    Maybe it's a mechanical problem like a warped ball screw?
    Do you have any pictures of the problem?
    Paul
    Jul 2005
    29
    Thanks for the input, I put a dial indicator on and jogged up and down and the screw seems fine. I added a drawing above, a picture doesn't really show as it's only about .003" which also answers I don't notice the axis moving but can see on the finished product.
    May 2005
    2502
    That's very bizarre. I would try a post over on the Mach3 boards. It sounds like you're pretty convinced it is a controller problem of some kind. Now you have to figure out if it is Mach3 or Smoothstepper.
    Have you completely ruled out the possibility your CAM program is doing something strange?
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Jul 2005
    29
    Thanks Bob, I haven't ruled anything out at this point. I can't conceive how it could be anything mechanical as it is so perfectly contoured, loose spindle or guide, backlash, etc. would give a more irratic behavior I would imagine. CAM was the first place I looked but as far as I can tell the Gcode looks good but I am no expert. Heres a sample of code:
    T1M6
    G17
    G0Z0.9862
    G0X0.0000Y0.0000S12000M3
    G0X-0.3003Y-2.2879Z0.2362
    G1Z-0.1120F60.0
    G1X0.2257Z-0.1117F180.0
    X0.3282Y-2.2875Z-0.1120
    X0.4864Y-2.2804Z-0.1120
    X-0.0278Z-0.1107
    X-0.4775Y-2.2801Z-0.1120
    X-0.5935Y-2.2729Z-0.1120
    X-0.0792Z-0.1100
    X0.4544Z-0.1110
    X0.6087Z-0.1120
    X0.7104Y-2.2654Z-0.1120
    X0.1969Z-0.1094
    X-0.3294Z-0.1099
    X-0.6952Z-0.1120
    X-0.7839Y-2.2579Z-0.1121
    X-0.2627Z-0.1090
    X0.2586Z-0.1089
    X0.7798Z-0.1119
    X0.8034Y-2.2576Z-0.1121
    X0.8764Y-2.2504Z-0.1120
    X0.3616Z-0.1084
    X-0.1662Z-0.1079
    X-0.6875Z-0.1105
    X-0.8613Z-0.1120
    X-0.9332Y-2.2429Z-0.1120
    X-0.4259Z-0.1080
    X0.1071Z-0.1070
    X0.6273Z-0.1091
    X0.9484Z-0.1119
    X1.0160Y-2.2354Z-0.1120
    X0.5021Z-0.1076
    X-0.0181Z-0.1063
    X-0.5512Z-0.1080
    X-1.0008Z-0.1120
    X-1.0618Y-2.2279Z-0.1120
    Jul 2007
    1602
    Does the shape come out properly or does it look as though you are missing steps?
    Can you try it again using the parallel port? Preferably on the same computer.
    Have you ruled out any mechanical issues? It almost sounds as though there is play in the Z coupler where the motor raises the spindle and then the screw unwinds and drops the spindle down a hair.
    Oops you posted again while I had the window open....
    bob
    35538
    Can you post a picture?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2005
    14
    Can you run over the surface again with no change in settings and look at the changes?
    Jul 2003
    1758
    is this a stepper machine? How many thousands per full step of the stepping motor?
    sam
    i had a similar issue on my first machine build , the y screw was running off center ever so slightly and it would bounce the z assembly a thou or two , it was easy to tell on mine because the lines on the parts matched up with the pitch of the screw
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Jul 2005
    29
    Thanks for all the great ideas, I will be investigating this further this weekend. First by removing the smooth stepper from the equation. I'm not going to dismiss any idea no matter how unlikely I "think" it maybe. I will post back tomorrow with any updates. Thanks again for the input.
    Robert
    Mar 2006
    489
    I'm with samco, if it is a stepper machine, maybe it's snapping to the closest full step rather than real microstepping.
    I see this behavior on my plasma table, not that it matters on that machine.
    Paul
    Jul 2005
    29
    Certainly an interesting thought. It is a stepper/ballscrew setup. I'm using cnc4pc c23 bob with G201's. What do you feel would be the likely cause for that senario, Gecko or motor?
  1. 8 finish in an ID
    By race8082 in forum MetalWork Discussion
    Last Post: 08-08-2009, 04:22 PM
  2. Zinc-Plated Finish vs plain finish for threaded rod?
    By Almaz in forum DIY CNC Router Table Machines
    Last Post: 10-21-2008, 08:39 PM
  3. Finish on M2
    By yoopertool in forum Mass finishing equipment/media/strategies
    Last Post: 03-26-2008, 12:43 PM
  4. How to get this finish
    By dneisler in forum Uncategorised MetalWorking Machines
    Last Post: 10-12-2007, 01:09 AM
  5. Bad finish
    By fadalman in forum Fadal
    Last Post: 12-09-2006, 08:00 PM
