Greetings, been gone for a while; tragedy struck, now I am back to hopefully finish the build, my account happened to get linked with several others and I lost some of the content, so starting over, tech is still trying to figure it out; have a temporary screen name of Jay-D9.
Everyone has a bad day now and then, so when you do just stop by here and see it there is an update and watch this wood butcher try to build a CNC router for some funny laughs.
Not going to pretend I'm a carpenter but going to give it a go just the same. Have a few basic tools; nothing fancy.
Hopefully I will get a 2'x4' cutting area, would like to build it eclosed for dust containment.
Started out scoring some 9 ply 3/4 inch birch plywood from our local home center and cut into pieces to build the bed.
Building the box.
Using 2×6’s laminated 3 thick for the main supports, staggered the joints and glued and screwed them together.
Putting the base frame together with wheels for now just for convenience.
Slid the base into place and fastened it.
This is going to take a while…. wow
Cheers – Jeff
