587,404 active members*
3,192 visitors online*
Results 1 to 4 of 4
    May 2014
    261
    UCCNC G-Code Line Limit?
    Does anyone know if there is a line limit to UCCNC?
    I tried doing some dynamic milling which produced a lot of lines of G-Code for a fairly simple operations, but when I tired to do a few simple things together UCCNC refused to load the code.
    I had to break the operation up into smaller operation files to be able to do it.
    Now I am using an old POS (Point Of Sale) machine that is running Windows XP, so it probably isn't the gruntiest of PCs. Is it a limit of the software or a limit of the PC?
    This is one of three pieces I needed to break it up into to get it to load.
    The other thing is once it was loaded and I tried to jog, it took ages to respond to the command. Like several seconds.
    If my post is missing an 'nt you might have to add it yourself.
    Re: UCCNC G-Code Line Limit?
    No, there is no line limit to UCCNC.
    Arturo Duncan
    https://cnc4pc.om
    35538
    Older version I think are memory lmited, but there's no hard line number limit.
    The newer 64 bit versions can handle millions of lines of code.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2014
    261
    Thanks guys. I am in the middle of building a new stand with another PC that supports 64 bit / Win7. So hopefully that sorts out the issues.
  1. Stepcraft 840 stuck axis limit switch UCCNC issue
    By yafimski in forum UCCNC Control Software
    Last Post: 12-07-2019, 10:34 AM
  2. Replies: 6
    Last Post: 04-21-2019, 07:16 PM
  3. SolidCAM line, arc, rapid G-code in every line
    By iIsTi91 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-13-2018, 06:56 AM
  4. How to make Mach3 go line by line in the g-code?
    By flyingpickles in forum Mach Mill
    Last Post: 02-07-2015, 09:18 PM
  5. Replies: 3
    Last Post: 04-08-2011, 01:48 AM
